Miso, my qualification is in Computer Systems Engineering (Read: Software Engineering). My current role is hard to describe, basically I do semi-HK IT stuff (ie not "Have you tried turning it off and on again" ) :)
Please don't remind me how much I hate virus removal.
Isola, what sort of amps/guitars do you have?
Currently rocking the epiphone les paul and some shitty fender acoustic. And before you flame, epiphone aren't that bad of a guitar!
12 string electrics are sick. I had one for about 2 years, it was a shitty brand one 'vester' I think, but god damn did it sing.... bit of distortion and downtuned..... holy crap. It rang out like a bittttttttch, I used it in some recordings for its thick, lush, dreamy tone.
Mmmmmmmmmmmmmmmm I'm moist
Love the Epi LPs! Had one for a while. Custom Shop arctic white with gold hardware... loved it. Had to sell it :) hoping to get another one one day!
At the moment I have:
Cort Acoustic
Gretsch 6118 Double Anniversary
Gretsch 5124W Baby Falcon
Gretsch Special Jet
Raven 12 string
The only amp I have is a Roland Micro Cube. Had to sell my VOX VDT50 a while back :dry:
I'd like to get a Matchless amp or a Vox AC30 when I have spare money lying around.
What about you?
I've heard its bad for you anyway :)
I'm going to bed now... but I wouldn't class it as sleep. It's more... my body is at the point of physical exhaustion and if I don't give it somewhere comfy to reboot it will just turn me into a bike rack somewhere...
I'd pay to see that :dry:
Watch your head :)
I bet you would, perv :dry:
Oh don't worry, I've been walking in that army infiltration crouch around the house for the last two days.
Catch ya later!!
Commando rolls as well ?
Nighty night.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
