SUPSUP
Sounds like an interesting night.... I bailed and played ps3 at my mates after Martin said not to bother lol
The laser's staying at drift king over the weekend it seems :P after a bit of a chat with mike, I'm pretty confident it'll be bulletproof once it's all fixed up hahaha
Went to the art gallery today... I mean really what are they passing off as art ? There was kitty litter spread out on the floor. < art apparently. The was a 3 min video of two guys chewing gum. A 2 min video on how to make a paper clip. A inflatable rabbit and a chair with a log jammed through it.
What the hell was that all about ?
Is it just me or has art gone shite ?
jason art is always shit, in fact get me some canvas i'll wipe some of my own shit over it and that'll be art.....
no sorry. The difference between art and shit is a signature
hahaha that's awesome, Miso!
not actually getting them.
bit bored and was discussing with my bro, that if i won the lotto, i would get these plates and stick them on a hummer...
A few months ago there was this room with string hanging from the ceiling and you could walk through it.
Mindf**k and a half.
No Tarlae for me? :(
Ah sorry mang, didn't end up coming out with us last night so I didn't bother you hahahaha... I did just see her about an hour ago though lol
Also the ravbat is once again single :D:cool:
oh sweet my garage floor is art! Stoopid cat and his excessive digging habits
All good mang. Next time :(
Sad Panda :)
Well looks like theres going to a Australia-Serbia showdown to have any hope of remaining in the world cup.
Miso, if you are going to watch the game, I don't want to be anywhere near you :D
Will be a good one. Watching Croatia v Australia last world cup was shit enough, so shall see how this one goes
Aussies got ripped off last night, but anyways.
I love how the 'coastguard' didn't even look at mine or the volvo.
If it had a baby seat in the back, they would never beleive it was me.
Damn you john!
There are some good things about a 4door!
Damn you john!
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
