I just realized that since the mrs aint here, I GOT NO DINNER!
Off to KFC. :P
I figured that Isola would have a feild day with this post.
don't forget to pick up some grape drank!! and don't spill any in the maxima!!
Tristan's having a bad day:
Tristan Gamack - For Sale: Tristan's 1992 Nissan 180sx Drift Car
- Condition: Piece of crap that i f**king want to kill
- Price: $50.00, however i might be tempted by a packet of salt and vinegar chips
morning mangs
scarnon
Coffee then beer at 10am. You ? :banana:
recovering from a weekend with little sleep... That's what works for.............right? o.0
Yep damn right. Only chuck a strayen day to go fishing and maybe the pub. :)
Can't sleep at my new tiny desk :banana:
Coffee then beer at 10am. You ? :)
Red bull then no beer at 10am :(
Think if i take my XF + trailer and a packet of chips round to tristan he'll let me take his tractor?
