What is it that you do that you get to work from home?
I'm a Bio Medical service engineer.........ooooo aaaaaaaah....... glorified guy with screwdriver.
Originally based in Melbourne but did the shift up to Brisneyland, but there is no office up here. It's just myself and the sales guy. It seems to work ok, but I have bad motivation days sometimes.
In other news,
I was gonna come out last thursday but you know, not driving a riceline and all I would feel left out. Plus, I don't have a hat.
I wouldn't worry about that we discriminate equally. You'll only get as much shit as everyone else :D
Come out anyway. Jason and I are both big Ford fans. You can hang with us :(
+1
your at your desk at work at 7:39am
sucks to be you
ill get to mine around 10, and be home by 3... :)
6:30 - 5 :( And they call mine the afternoon shift lol.
account manager
work in wholesale with the major CE retailers and FMCG retailers...
basically been in sales now for 11 years...
Eat a bagel, like a boss... send some fax's, like a boss... etc etc
Shit on Debra's desk?
spose i better go iron a shirt and go to work...
need to stop by the bank and post office etc on the way... might take an hour...
also feel like a HJ's brekkie wrap for some strange reason today... ummmmm
Man FU I feel hungry now. HJs is pretty close though...hmmm...
Atleast you get a screwdriver :D
I'm a 10 - 3er as well but it's not by choice, I'd work all day if I could. *brandishes fist*
living 5 minutes from work is pretty great too, I leave ten minutes before hand, enough time to fire the car up head down to nightowl and get an ice coffee, have a cigarette then drive over the road to the shop.
And chyeah I'll probably come out on thursday night, a friend of mine who drives probably one of the most horrid skylines in Australia might come as well. I'll tell him to park around the corner simply so you don't have to look at it.
Who should I be looking for? Or do you guys stand near your cars poppin hoods n shit?
Edited by hylian
Any work going there ?
Morning all.
Fords are awesome. :D
http://www.skylinesaustralia.com/forums/We...ns-t316913.html
no hoods are popped, unless there's a boost controller installed wrong.
Or there's a 34 NUR there :D
We sit at the tables out the front of the baskins store, unless someone crims them before we get there, which is unlikely during winter :)
We cant pop hoods. To much attention from our coast guard friends. That and if I go near my car, they assume that I stole it. :D
On the other hand though. I did find a twin turbo kit for the v36 w/ Garrett GT28RS's. FTW!!
Also got some sort of rough price estimate. So its' looking awesome.
Was also told that with someone that knows whats going on and decent tune - high 10s! FTW!! :)
Don't worry Isola, just for you i'd attach a few hot paltes to the back.
Now, does anyone know of a decent accountant taht can work this into my claim next year?
haha! Work expenses. Yes sir, I required a car that was stock 245kw to be twin turboed for work purposes. Why?
Because i <3 my clients and get there quickly to meet them. :(
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
    • Could be correct. Meter might be that far out. Compare against a known 5 ohm 1% resistor.
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap.  (edit: I went out and did it right now, the line I had chosen did appear to have no vacuum on it, it used to go to the front of the intake, I've now completely blocked that one off at the bracket that holds several vacuum lines by the firewall.  I T'd into the vacuum line that goes from that bracket to the vacuum pump at the front of the car, but no change in the MAP readings).  Using the new vacuum line that has obvious vacuum on the hose, im still only getting readings between -6.0 and -5.2.  I'm wondering why the ECU was detecting -5.3 when nothing was connected to the MAP nipple and ECU MAP selected as the source. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
