That's how I read it, anyway.
Truth, this man speaks it.
they won't be a chance, all the half decent kents will be too old / retired
Hopefully some new younger kents will come through the ranks. The old kents are shite anyway
No, KFC?
In?
They have decent kents now ? :D
Can I buy a vowel ? :)
Buy a vowel get 2 consenants free.
THEY HAVE HOT RODS BACK?!?!?!??!?!?!?!?!?!?!?!
*victory dance*
Really?
we totally should!!
KFC needs all it's spicy options available at all times!
+11ty
Comin out tonight mang?
There is a ranga as P.M.
Should we be afraid of you now ? :)
Actually had a valid point but got distracted by a piece of lint flitting around now I can't remember it :blush:
Is that because she would get lost ?
That and how the f**k are we supposed to have a revolution without sammiches?
:verymad:
:cool:
ps col - england made it thru - i wasnt expecting that :P
Cus ur a dog. I knew it all along :P
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
