I still have a tax bill from last year - the first time I used an accountant.
I work two jobs and they're both under the free threshold but the accountant picked up on it and charged me ahhaha. so now I use the eTax and it doesn't recognise it, I still earn piss all money so I guess it's fair. In fact I'm probably paying more tax earning 40k combined than someone who earns 40k in one job.
That doesn't make any sense at all
LOL @ the goal england didn't get. That ref was a sped
Well I figure that you pay so much tax because you have one job right? so you'd be paying more if you have two because you get taxed through the ass for a second income. So why should you be paying more tax for two jobs when the total income is still low?
You get taxed based on what you earn. It doesn't matter if you get it from one income stream, 2, or 27. Add it all together and thats what you pay tax on.
The tax-free threshold should only be claimed with the payer who usually pays the highest salary or wage (this is known as your primary source of income). If you earn any additional income (for example, from a second job) then your other payer is required to withhold tax at a higher rate.
From the ato website
colin them rims should fit ok, if not, then spacer love.
Sanded back another panel on my 31 before it got way too cold outside to be wearing shorts and shirt. hopefully will get onto the front quarters tomorrow night before futsul
thats how much they withhold. What you pay at the end of the year stays the same
otherwise if you claim the tax three threshold on both, you would get a big bill at the end of the year because you wouldn't have taken enough out during the year
So... are any of you so ridiculously rude that you would demand a coffee/tea when you were a guest in someone's house instead of waiting to be offered?
GF's loud-ass skanky rude friend is over, and I was walking into the kitchen and was asked by the GF "Can you please check the cake in the oven and see if it's done?"
And her ignorant bitch of a friend goes "And check the kettle too."
WTF?! This bitch has NO manners. The first time I met her was at the Albany Creek Hotel. We went there for dinner. Halfway through the meal she looks at me, points at my steak sauce, and says "Is that mushroom?". I nodded... she grabbed my sauce, and poured half of it on her plate :cool: no asking, no checking if I was done with it, just *grab*. Completely destroyed my sauce to meal ratio that I had in place.
I pushed my plate away and sat there glaring.
Hated her from that moment, and tonight just reinforced it.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
