I still have a tax bill from last year - the first time I used an accountant.
I work two jobs and they're both under the free threshold but the accountant picked up on it and charged me ahhaha. so now I use the eTax and it doesn't recognise it, I still earn piss all money so I guess it's fair. In fact I'm probably paying more tax earning 40k combined than someone who earns 40k in one job.
That doesn't make any sense at all
LOL @ the goal england didn't get. That ref was a sped
Well I figure that you pay so much tax because you have one job right? so you'd be paying more if you have two because you get taxed through the ass for a second income. So why should you be paying more tax for two jobs when the total income is still low?
You get taxed based on what you earn. It doesn't matter if you get it from one income stream, 2, or 27. Add it all together and thats what you pay tax on.
The tax-free threshold should only be claimed with the payer who usually pays the highest salary or wage (this is known as your primary source of income). If you earn any additional income (for example, from a second job) then your other payer is required to withhold tax at a higher rate.
From the ato website
colin them rims should fit ok, if not, then spacer love.
Sanded back another panel on my 31 before it got way too cold outside to be wearing shorts and shirt. hopefully will get onto the front quarters tomorrow night before futsul
thats how much they withhold. What you pay at the end of the year stays the same
otherwise if you claim the tax three threshold on both, you would get a big bill at the end of the year because you wouldn't have taken enough out during the year
So... are any of you so ridiculously rude that you would demand a coffee/tea when you were a guest in someone's house instead of waiting to be offered?
GF's loud-ass skanky rude friend is over, and I was walking into the kitchen and was asked by the GF "Can you please check the cake in the oven and see if it's done?"
And her ignorant bitch of a friend goes "And check the kettle too."
WTF?! This bitch has NO manners. The first time I met her was at the Albany Creek Hotel. We went there for dinner. Halfway through the meal she looks at me, points at my steak sauce, and says "Is that mushroom?". I nodded... she grabbed my sauce, and poured half of it on her plate :cool: no asking, no checking if I was done with it, just *grab*. Completely destroyed my sauce to meal ratio that I had in place.
I pushed my plate away and sat there glaring.
Hated her from that moment, and tonight just reinforced it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
    • It sounds like you want what the Toyota Landcruisers have for their roof racks. Wanna know what you end up with? Rust holes in the roof, and water everywhere...
    • Discovered today that if I select reverse first and take my foot off the brake, then select drive, the drive indicator light works and so does the tiptronic gear indicator.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Does anyone here have any ideas?   Cheers guys
