Fark all brah. School holidays so entertaining the kids. Taking them to the indoor playground thingo today, they fkn love that shit! Milf watch for me.
Sounds like a good day mang. I'm working till like 1 then we've got the work end of year touch football game/drinks/dinner so should be good.
For those that don't read my build thread:
OK, I've had my fun, here 'tis:
And for Colin:
No wait, that isn't right :D.
I only got 1 cat each side, the ones on the headers:
I think it has 5/6/7 cats in total, but the rest are further downstream in the exhaust system.
Unfortunately because the exhaust collects straight into a cat those headers are no good to me, so I guess its going to have to be custom headers (oh no, how sad)
It is the same engine as one of these:
But mine is not out of a GTA so it doesn't get the "GTA 3.2" stamp on the plenum
Also. the pallet had a mysterious white powder on one corner when I picked it up:
Dan tried it, he said it wasn't any good:
ATTN: Anyone who knows about trailers
My dad is out somewhere in the middle of f*cking nowhere, with his sailing boat on a trailer with pissy little 8" wheels on it. Apparantly the wheels have not held up well to the trip out there (and he still has further to go!), so he wants to put bigger wheels on it for the trip back.
He asked me to find out what the options are for him.
So whats the go? Are these wheels likely to be a standard PCD etc so he just needs to find bigger wheels with the same PCD. What would it be?
Or does he need to replace the hubs? Do all trailers have the same stub axles or does he need to find out what his has?
Any help would be appreciated, I know nothing about trailers other than how to hitch them up to cars and tow stuff with them :D
Edited by Smity42
Any help would be appreciated, I know nothing about trailers other than how to hitch them up to cars and tow stuff with them :P
Just for clarity, does he have a r33, or an actual boat on the back of the trailer?
if it is an r33, drive it off the trailer and drive it here.
If it is an actual boat, attempt to sail it here?
I accept your many thanks in advance
Martin - there are 4 and 5 stud trailer hubs. Most of the 4 stud are 5.5 INCH PCD which is ummm.. *counts* 140mm (as long as I've woken up enough to work out that math right...)
Any wheel will fit if it has the correct PCD, so he could put 13s on if he can find them. How big is the boat (weight wise) because trailer tyres have load ratings like car ones, so if he can work out what tyre he needs, he'll know what rims he needs. My suggestion would be getting tyres/rims that can handle at least half that weight again to take anything else on board into account (fuel, rods, air tanks, blah blah blah, you get the point).
That's really all I know about boat trailers, and it's been far too long since I've really has much to do with them, but hopefully that's SOME help.
The 5 studs I can't remember the PCD for though, so you'll have to hope he has 4 stud :)
Failing just living on hope you could get your Google on and show up that MUZT3K fuckwit :P
An actual boat.
Thanks for pointing out that lack of clarity in my post, it could have caused much confusion. Although, I wouldn't want to be towing a 33 on anything with 8" wheels!
Re sailing it back - he's going to lake eyre, there is no path of water to sail it back.
The boat is a tiny little sailing boat (monohull), weighs nothing. He has stacked up the trailer with supplies though, good point.
I've been getting my google on (instead of working) but so far I'm just getting more confused, i've found dozens of different 'common' stud patterns, and even a lot of 8" wheels that ARE the hub, ie the wheel attaches directly to the axle on a bearing.
I can't remember if dad's is 4/5 stud or if its a funky bearing one, I'll have to wait till he rings again because it's going straight to voicemail (he has to drive to the top of a hill and plug in his big antenna to get reception, lol NextG is shit)
Thanks for the help broseph
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
