Fark all brah. School holidays so entertaining the kids. Taking them to the indoor playground thingo today, they fkn love that shit! Milf watch for me.
Sounds like a good day mang. I'm working till like 1 then we've got the work end of year touch football game/drinks/dinner so should be good.
For those that don't read my build thread:
OK, I've had my fun, here 'tis:
And for Colin:
No wait, that isn't right :D.
I only got 1 cat each side, the ones on the headers:
I think it has 5/6/7 cats in total, but the rest are further downstream in the exhaust system.
Unfortunately because the exhaust collects straight into a cat those headers are no good to me, so I guess its going to have to be custom headers (oh no, how sad)
It is the same engine as one of these:
But mine is not out of a GTA so it doesn't get the "GTA 3.2" stamp on the plenum
Also. the pallet had a mysterious white powder on one corner when I picked it up:
Dan tried it, he said it wasn't any good:
ATTN: Anyone who knows about trailers
My dad is out somewhere in the middle of f*cking nowhere, with his sailing boat on a trailer with pissy little 8" wheels on it. Apparantly the wheels have not held up well to the trip out there (and he still has further to go!), so he wants to put bigger wheels on it for the trip back.
He asked me to find out what the options are for him.
So whats the go? Are these wheels likely to be a standard PCD etc so he just needs to find bigger wheels with the same PCD. What would it be?
Or does he need to replace the hubs? Do all trailers have the same stub axles or does he need to find out what his has?
Any help would be appreciated, I know nothing about trailers other than how to hitch them up to cars and tow stuff with them :D
Edited by Smity42
Any help would be appreciated, I know nothing about trailers other than how to hitch them up to cars and tow stuff with them :P
Just for clarity, does he have a r33, or an actual boat on the back of the trailer?
if it is an r33, drive it off the trailer and drive it here.
If it is an actual boat, attempt to sail it here?
I accept your many thanks in advance
Martin - there are 4 and 5 stud trailer hubs. Most of the 4 stud are 5.5 INCH PCD which is ummm.. *counts* 140mm (as long as I've woken up enough to work out that math right...)
Any wheel will fit if it has the correct PCD, so he could put 13s on if he can find them. How big is the boat (weight wise) because trailer tyres have load ratings like car ones, so if he can work out what tyre he needs, he'll know what rims he needs. My suggestion would be getting tyres/rims that can handle at least half that weight again to take anything else on board into account (fuel, rods, air tanks, blah blah blah, you get the point).
That's really all I know about boat trailers, and it's been far too long since I've really has much to do with them, but hopefully that's SOME help.
The 5 studs I can't remember the PCD for though, so you'll have to hope he has 4 stud :)
Failing just living on hope you could get your Google on and show up that MUZT3K fuckwit :P
An actual boat.
Thanks for pointing out that lack of clarity in my post, it could have caused much confusion. Although, I wouldn't want to be towing a 33 on anything with 8" wheels!
Re sailing it back - he's going to lake eyre, there is no path of water to sail it back.
The boat is a tiny little sailing boat (monohull), weighs nothing. He has stacked up the trailer with supplies though, good point.
I've been getting my google on (instead of working) but so far I'm just getting more confused, i've found dozens of different 'common' stud patterns, and even a lot of 8" wheels that ARE the hub, ie the wheel attaches directly to the axle on a bearing.
I can't remember if dad's is 4/5 stud or if its a funky bearing one, I'll have to wait till he rings again because it's going straight to voicemail (he has to drive to the top of a hill and plug in his big antenna to get reception, lol NextG is shit)
Thanks for the help broseph
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
