exxy kit though atleast it's a grex one though. Just jap ones are only $400 new
they also suck and leak, on my other 32 i paid for the kit then had to pay another 200 for decent lines = not so cheap anymore :D
my trust kit on the 31 leaked
...but that was because I was missing an O ring :D
justjap ones have no thermo and are not as quality as the trust/grex
Yeah you want the thermo in it, otherwise it takes forever to get up to proper operating temp. Not good.
I wanted it lol was looking for one for ages and then I lost my job and found it. Was like dammit!!!! :D
I'm not TOO fussed as it's for my track car, so it won't spend much time cold. But I would prefer a thermostat.
Ah yeah, still good to have. Shorter the engine is cold the better.
Oh I want a track car :D
one man mexican wave?
You know it
Quick question, would a leaking water pump keep your radiator coolent level but empty your reservoir?
Leaky radiator cap ?
Could do as when the car cools down it will suck the water in from the reservoir. Fill it up and take the car for a drive and get it hot then have a look to see with the car running if its blowing any bubbles or anything in the reservoir. If it is will be a blown head gasket. Check that the reservoir isn't split been that its plastic as well. Have seen this happen before.
Just some things to look at.
Hope this helps
In a properly working cooling system it will empty your reservoir first, but it would eventually start emptying the main cooling system (radiator) too.
But this is regardless of where the leak is in the system, it could be water pump, hose, just about anything.
Why do you suspect water pump?
After researching it seems like water pump failure isnt that uncommon. The car has never been overheated before but I've filled the reservoir up 3 or 4 times with coolent since my last service (8000km).
I can see coolent residue on the car when its up on hoist too but never a patch of green stuff when I park.
What I wanna know is how is the system diagram like... what goes where. I might try googling and see if anything comes up.
ps: I'm hoping its the water pump because I'm changing that out this weekend for major service!
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
