exxy kit though atleast it's a grex one though. Just jap ones are only $400 new
they also suck and leak, on my other 32 i paid for the kit then had to pay another 200 for decent lines = not so cheap anymore :D
my trust kit on the 31 leaked
...but that was because I was missing an O ring :D
justjap ones have no thermo and are not as quality as the trust/grex
Yeah you want the thermo in it, otherwise it takes forever to get up to proper operating temp. Not good.
I wanted it lol was looking for one for ages and then I lost my job and found it. Was like dammit!!!! :D
I'm not TOO fussed as it's for my track car, so it won't spend much time cold. But I would prefer a thermostat.
Ah yeah, still good to have. Shorter the engine is cold the better.
Oh I want a track car :D
one man mexican wave?
You know it
Quick question, would a leaking water pump keep your radiator coolent level but empty your reservoir?
Leaky radiator cap ?
Could do as when the car cools down it will suck the water in from the reservoir. Fill it up and take the car for a drive and get it hot then have a look to see with the car running if its blowing any bubbles or anything in the reservoir. If it is will be a blown head gasket. Check that the reservoir isn't split been that its plastic as well. Have seen this happen before.
Just some things to look at.
Hope this helps
In a properly working cooling system it will empty your reservoir first, but it would eventually start emptying the main cooling system (radiator) too.
But this is regardless of where the leak is in the system, it could be water pump, hose, just about anything.
Why do you suspect water pump?
After researching it seems like water pump failure isnt that uncommon. The car has never been overheated before but I've filled the reservoir up 3 or 4 times with coolent since my last service (8000km).
I can see coolent residue on the car when its up on hoist too but never a patch of green stuff when I park.
What I wanna know is how is the system diagram like... what goes where. I might try googling and see if anything comes up.
ps: I'm hoping its the water pump because I'm changing that out this weekend for major service!
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
