Find me a new sticker and I will. Has to be something cool though! It's only still there because I have nothing to replace it with.
name what you want and ill buy it :yes:
F*cking lol
just bought it.
thats f**king love right there flamin mongrel
<3
Lets all get naked?
You are one hit tipping worthy mang :)
+1
i'm a man of my word :)
What about that time you said you wouldn't get it in my eye?
sup
Scarnon mang
Ravbat! What's crackin?
Hahahaha I ninjad my post my last night... hit it and bailed as soon as it was posted cause I didn't think anyone else was online... your post was 1 minute after me! Hahaha!!
Riding a Horse - You're doing it wrong!
f**kING. LOL.
Think im gonna need a phoneworthy... I'm running out of time
The pig is roadworthy motherf**kers. Rego on Monday n then I get to drive again hoorah! Car is still getting too hot though. its on like 3/4 on the gauge. Radiator isn't blocked but I dunno. The electric fan isn't coming on when its getting too hot though. Ideas?
checked the thermo and water pump?
