Im in Sydney both of those dates. :down::)
Well done with those letters, well written so hopefully people will perk up to it.
Write to Today Tonight or ACA about it. That would make for interesting TV.
Yeah why not should be good for shits and giggles.
Which Wed (21st or 28th) ?
That's what he's asking. What will people prefer/go to.
I'll change my preference to next wed (28) because i may still be a bit sick this wed
next wed it is the 28 im in for that
PORN LADY UPDATE
Yep she did lose her job.
THE END
luls that is pretty bad
Mangs *tips hat*
out for gemania in for thursdayia
Mang *waves salmon*
These both look damn sexy on me:
But then again so do these ones:
Nobody had these ones for me to try :D
The incredibly hot chick @ sunglass hut said I should get the plastic ones, but then wouldn't give me her phone number (even when I had them on) so her opinion is no longer relevant.
They are that cheap on eGay I might get one set of the wires and one of the plastics...
sunglasses
I think Straight Jackets look like sunglasses lebs or terrorists should be wearing and they make white guys look like roid munching asswanks.
I'm not a big fan of the new Minutes, I really liked the old ones though. My vote goes for the Square Whiskers still.
I should get new rubber for my Juliets and wear them again.
Hahaha john i do have a set of Straight jackets..... are you saying im a terrorist? You've got it all wrong though, white boys that look like roid munching asswanks only buy them in white.
An interesting opinion, because I think they are the only two models in the current plastic range that don't look like completely overdone arse-wankery.
Exhibit A, Juliet:
What's with the gay bit sticking out in the corner? FFS, they would be good if not for that. Same deal with the pennys, except they are even worse.
Exhibit B, Jawbone:
What wanker would be seen in those?
Exhibit C, all the rapper/gangsta spec big square shit things:
And all the other models that fit that category too...
And then the half frame ones, I can't stand any of them:
Straight jacket and minute seem to be the only sensible ones left. Agreed though, old minute was much better (as was old straight jacket).
I think I'll definitely get a set of the square whiskers, although I'll sleep on it and decide tomorrow. May get a set of minutes as well for the odd occasion I have to do something sport-like :P
You are a terrorist. And yeah any plastic sunnies in white definitely makes you a cocknugget roidhead
That's where the screw is to hold the lens in. It's stronger having it there instead of being the same one that the arms swivel on.
They're probably the most comfortable sunglasses I've ever owned too :P
The Pennys are smaller than the Juliets that might be why it looks more odd to you?
Edited by Isola
yeah, i've officially re-assesed them, since they are metal and that knob is functional, I like them :P
a little on the pricey side though :) EDIT: And none with black lenses without going "custom" (uleh)
looking on ebay now...
Edited by Smity42
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
