sup mangs. New dirty 30 has been acquired. Dad reckons bit of sump damage getting it out of the car :S Will check the pick up and make sure it is sweet if not I have a spare from the dead motor lol. He also said looks like it may have had some work done recently. Core plugs in the side of the block all look fairly new and so does the thermostat.
f**k yeah!
What's new guys?
I have a license martin, you give me his details and pay my travel expenses and i will deal with the matter and get you your porker brakes
His name is nik (yes nik) and he lives in south yarra somewhere. k go
f**k yeah!
What's new guys?
RAVBAT! Scarnon mang, we missed you :down:
that f**kin sucks Mcfly :) Sexy brakes those ones aswell.
Boring day at work today got a fair bit done though. Day off/uni tomorrow though :O Also mangs does anyone have a clutch alignment tool and/or a torque wrench I can borrow?
RAVBAT! Scarnon mang, we missed you :O
And I, you! :)
f*cking paypal are giving him another 10 days to respond before they 'decide on out outcome'
its already been 2 weeks since i last got a message from him!!!!
Megaepicpaypalfail...... I hate red tape like the plague
If anyone's interested, I got the new laser roadworthied last week and transfered to my name.... done all the usual shit since, oil + filter, new radiator & coolant, she runs great now! Just have to adjust the carby so it idles a little higher once warm and I'll be pretty happy with it!
And I, you! :)
bring it out for ice cream so we can see it! Tristan brought the TRD Mazda to show us. Epic dish :O
yes and maybe
Sweet
Yeah paypal are f**ked...
And I, you! ;)
Sickness mang. Just needs more Baskins :D
colin i got a clutch aligning tool, will bring tommorrow
:O
hard drive cleanup!
Yeah mine could use a good clean but I'm scared of what I'll find if I go poking around in there :)
i found stuff i thought i'd lost...... :O happy times!
complete format and reinstall of my system, runs so much faster now it doesn't have so much crap on it
speaking of tracks
got a copy of Forza 3 the other day and finally got a chance to play it today. Pretty awesome game. The drifting bit takes a bit of practice... I totally munted the mines R34 drifting it up some mountain in Fujiama or something. Good selection of cars in it from what I've seen so far :P
speaking of tracks
for the xbox 360 ?
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
