whos in for german tonight?
i may be. depends on a few doctors appointments this afternoon.
been an eventful fortnight.
what time is it again? at work, and I don't feel like having a photo of hitler saved in my browsing history
but thats half the fun :(
I beleive Anna and i are still in.
Any one had any experience with Varex mufflers? My car is far far too loud, i love it but coming home late at night and rbts ect will be a hassle so im thinking varex could be the answer.
7pm. But you are a member I imagine, so it won't be a problem for you to get in if you're late.
No personal experience with them, but I hate the idea of them.
I dont love the idea, but i hate the idea of my car having to not sound like it does now on a full time basis more.
Dan got abused by some lady today due to its volume so i figure she wont be the only one that hates it
Tony.... that sucks.
Pics of ho's ex? (plus address and work timetable)?
Some SAU loving is in order here methinks..
Your gunna bone his ex too?!?
Dirty Ravbat :(
I was asking for the douchebag ex boyfriends details..... so we can all rock up at his place and deliver some SAU justice...
I'm not THAT much of a ladies man.....
Its meant to be loud.
you'd better use it after I went to all that effort :down:
You'll feel the love man. Just gotta wait for my puda bud to come around and hook me up.
Old man is a veritable 2 fingered typing terrorist on these things. :)
The truth, this man child, he speaks it.
IN!!
Getting closer
Also in.
looks like XXXX man isn't coming tonight, if Kyle doesn't want to come I'll def have to drive as catching the train by myself will be sh*t :(
Dan's a soft cock.
Will def be there tonight. Evening schedule just got cleared :)
Sickness mang :down:
You have to hear it, it isnt just loud, it is literally the loudest skyline i have ever heard, barring ones with a screamer wide open of course
and as per the german club thread I am out, feel like shit, need bed
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
