Well i just had a great friday! After getting a tax bill yesterday which made me a sad panda I got to work today to learn that i have received an $11000 a year pay rise!
On the downside i am so hungover
So went into Optus to upgrade my phone. They don't actually have any stock just getting everyone to sign up to contracts then new phone comes in the mail. Get a free month of service because of no stock but still a bit disappointing. Had a play with that new Samsung aswell. Pretty good but its a prick to type on.
I call BS. You camped (get it, as in being a poop skooter??) out at midnight last night so you could itouch some new plastic toys that Gapple made that is pointless as a phone.
12.30am, and JarJar Binks is all like "Me-sa So-rry, no more.......". That's when he got his head blown off and Hans Griffin lazily loited to the left........
Wait, my dreams are getting well f**ked.....
Lol
New security camera system installed the monitor on the wall doesnt support it as it isnt HD. The security guys were told to get a new monitor so now we got a brand new 42 inch LCD...
non HD
the security guys are like :D how come it dont work
im like :(:w00t: idiots :)
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
