Haven't posted in a while, I know you've all missed me. Moved out and haven't got around to calling up tpg yet, however I "gained" access to another network in the area.
Looking at importing a car in the next few, so many choices!
Welcome back :D
That 33 still dead?
What's top of the list?
RE porka brakes:
We have concluded our investigation into your case and have decided in your favour.
We were able to recover $530.00 AUD, and this amount has been credited to you. Please allow five business days
I really wanted those brakes, but at least im not out 500 bux I guess...
Welcome back :domokun:
That 33 still dead?
Hahah, replaced the coil pack, wiring loom and the spark plug and shes all go again. I told him to go get a series 1 coil pack, and wiring loom.
He came back with a series 1 coil pack and a series 2 loom.
Im thinking either 32 gtr or 34 gt r or gtt. Since its my first car off my p plates Ive been leaning more toward the gtt.
By the way, anyone who uses firefox here, when theyre replying to something and hit the apostrophe key does it bring up a find field?
at least it's all fixed now
are you sure you need to import a 34? there's a fair few of them here already. Fair enough if it's going to save you a heap of money, but otherwise it might be better to buy local?
no search field for me
I don't think it would even save you money importing a 34. All the skylines have been brought over in large numbers you may aswell buy one local since they are as cheap if not cheaper over here anyway. Only way you would want to import one is if it was a one off, low ks full logbooks collectors item.
Morning mangs
Morning mangs
Your up early.
How was the weekend ?
Your up early.
Up this time every morning :banana: Normally its a lot busier in the morning so I don't post until all my subbies are started work etc. Hardly got anyone working today :banana:
Weekend was a great success :)
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
