Morning mangs.
Slept in today :banana: , So now I'm stuck at work till almost 4pm :banana::D:(
Hows the p1g going colon? Rip a good skid yet?
Webber for WDC 2010!!!!!
Almost 4pm oh noes :)
No skids yet.
Hahaha Vettel was pissed
What happened?
Guy didn't send them.
What happened?
They never turned up, seller vanished off the face of the earth internets
Paypal ripped $530 off his credit card and gave it back to me though :)
Edited by Smity42
Dodgy seller fails at being dodgy
'allo guv'ner!
Yeah, but it means I now still need to find front brakes :)
Yeah that bites....
Onto other news, watch this vid. Look at 5:16. You get to see Tristan drifting...... I mean doing it wrong
damn, will have to wait till I get home
By 'doing it wrong' are you saying he's doing drifting wrong, or are you correctly pointing out that drifting itself is 'doing it wrong' as the fastest way round a racetrack is with grip? :)
ahaha, just hanging out on the side of the track.
I've been looking at alot of the import lots to get an idea of the prices of some of them. They really have come down in price but I'll still be prepared to pay 50 for a 34gtr, unless someone really wants rid of it and it's in good condition.
Job interview today!
45k will get you a decent 1999 GTR. DO ET!
Just had a quick look and 45k will get you a new SS Commodore, Ford 6 turbo or an XR5 Mondeo...
The 34 won't depreciate nearly as badly as a new car. May aswell by an 08/09 Commodore/Ford and save yourself 15k.
By 'doing it wrong' are you saying he's doing drifting wrong, or are you correctly pointing out that drifting itself is 'doing it wrong' as the fastest way round a racetrack is with grip? :domokun:
Yes
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
