R34s are still over priced and at 50k you are probably getting the higher k ones, the higher k ones are starting to show up pretty often for rebuilds now so factor in that too!
Just had a quick look and 45k will get you a new SS Commodore, Ford 6 turbo or an XR5 Mondeo...
The 34 won't depreciate nearly as badly as a new car. May aswell by an 08/09 Commodore/Ford and save yourself 15k.
I've already got an 05 xr6, I really want to get into a gtr; something different than the old taxi. I don't really give two shits about the depreciation on the skyline, it'll be something I'll keep for a number of years to come which is why I was thinking a 34 gtr or a rebuilt 32 like the one that's for sale on here at the moment.
Bunta, what do you mean by alot of them are coming in for rebuilds? Any particular reason or do they kick the bucket after 100k or so?
Buy this one
http://www.skylinesaustralia.com/forums/R32-Gtr-t329365.html
Very well priced for what you get.
I don't know of any specific problems with the 34, I assume they will have the same problems as the 32s and 33s being poor oil control and ceramic turbos dying.
They shouldnt kill oil pumps like the earlier 32s though since they have the bigger oil pump drive on the crank. Other than that I'm not sure.
Oil control is the main one
Buy this one
Bingo!
And that is a damn well sorted 32 there!
I know right! 2.8 + 2530s = Drool
I considred a HKS 2.8 after talking to Dave Chilton, He bloody loves them, Claims they are the best kits he has seen and when he puts them in the balancing rig most of the time they need none or very very little. Sadly the budget didnt reach that far as the kits are dear as poison and my turbos would not have suited any more so even more $$ :)
Yeah 10k for crank, rods and pistons is a bitter pill to swallow. If I was to do a stroker it would be a toss up between the HKS and Jun. The Jun cranks are work of art and the lightest of the stroker cranks from the info I can find on em. They weigh the same as the stock crank.
Yeah they would be another great option *sigh* needs more money!
In other news...I think my non stroker engine is getting tuned today, if not today very very soon.
Awesome news :) When is it coming to Baskins?
Wouldn't mind going a 30DETT either. If there is a way to get the bonnet to close properly etc that's the way I would go.
yeah i considered that too, but yeah the whole bonnet closing thing didnt appeal and once again i would have been up for new turbos! I will just have to be happy with what i got until i get rich!
You guys is idiots sometimes.
You want to overtake the whoretown thread... but you keep posting in it!
Lol I thought that as well. Won't make much difference though :)
Yeah bonnet closing thing would piss me off I think. Need to win lotto. Or rob a bank. Or become a politician...
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
