just went through my first ever defect station
anybody want to take a rough guess at list of defects, if any?
no defects.
cop "does this have a blow off valve?"
me "......no?"
cop "rev it"
rev no whoosh, rev no whoosh
"you're right, keep driving"
I IS SOO JEALOUS OF YOUUU
nice one brother <3
when i had my android, i topped out one month at 700mb. but rarely went over 500mb, and i flogged the data on that thing. even when at home, id use that data not my wifi.
Seeing that makes me a sad panda... I'd ALMOST be tempted to take it off his hands (for free) if he gave me everything I needed to undo what he's done.
wtf happened to the engine?
It was sold with the car back in 2005.
Someone from Secret Drift ended up with the motor.. As a box of bits. Someone along the line gutted the tastey bits from the motor and sold the poor kid a dummy more or less.
My housemate has come to the conclusion this house is haunted.
On top of our fridge there's one beer bottle for every beer we've had (long story) anyway, so during the night they all crashed to the ground when we we're all asleep but it woke us all up as well from upstairs. I would have thought it was just the compressor has kicked on and its shaken the fridge a bit and caused them to topple.
So last night they thought it'd be a grand idea to get out the faithful and foolproof ouija board. They are all conviced the house is haunted and there's a ghost coming to f**k shit up etc.
Ideas on scaring stoner housemate?
ok, so today I headed along to Lakeside for the Legends return.
Awesome cars, lots of sun and a few crashed. The best bit of the day was sniper boobies.....
That is all.
I agree. Group A is awesome.
The photographer was my mate Craig. After you guys left, there were 2 accidents at the end of the main straight. Both cars drop a rear tyre in the dirt on the right hand side of the track and ended up spinning into the tyre barrier.
I know Craig got a few pics, I'll see if I can get a hold of them.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
