martin leech your own players! he's mine!
So i took the brumby to work today, checked it over on the hoist. Looks like im making a new exhaust sytem for natalie! also replacing tie rods and rod ends, and bushes, and seals, and trying to fix the stupid amount of movement in the shifter.
What is a brumby rated at carrying ? It's not a 1 ton is it ?
Slop in the shifter is from 2 things. THe split pin through the shifter into the linkage wears, as does the bottom bush that sits in the gearbox housing that the shifter sits in.
yer scott i can flex that roll pin that goes onto the selector shaft, i was goin to replace that, can you still get them genuine? haha can still get front shocks for them, $150 a corner, everywhere else is wanting about $550 a pair trade cost. As for the exhaust i'll make one up during the week and fit it up when i get back. Really could do with a tune up, also replacing the filters and fluids.
Whats a good gearbox oil to use?
Edited by Dan_B
You should be able to get a roll pin new still. NOS or something.
Any hypoid type gearoil is what's in order with those boxes. Depends on how fast you want to shift I guess....
Yes! that is awesome port! I need to get me more of that.
Cheers for the advice, i'll just roll with some of the 75W-90 Penrite i got here, doubt the oil has been done in a long time, probably low with the amount of oil everywhere around it
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
