martin leech your own players! he's mine!
So i took the brumby to work today, checked it over on the hoist. Looks like im making a new exhaust sytem for natalie! also replacing tie rods and rod ends, and bushes, and seals, and trying to fix the stupid amount of movement in the shifter.
What is a brumby rated at carrying ? It's not a 1 ton is it ?
Slop in the shifter is from 2 things. THe split pin through the shifter into the linkage wears, as does the bottom bush that sits in the gearbox housing that the shifter sits in.
yer scott i can flex that roll pin that goes onto the selector shaft, i was goin to replace that, can you still get them genuine? haha can still get front shocks for them, $150 a corner, everywhere else is wanting about $550 a pair trade cost. As for the exhaust i'll make one up during the week and fit it up when i get back. Really could do with a tune up, also replacing the filters and fluids.
Whats a good gearbox oil to use?
Edited by Dan_B
You should be able to get a roll pin new still. NOS or something.
Any hypoid type gearoil is what's in order with those boxes. Depends on how fast you want to shift I guess....
Yes! that is awesome port! I need to get me more of that.
Cheers for the advice, i'll just roll with some of the 75W-90 Penrite i got here, doubt the oil has been done in a long time, probably low with the amount of oil everywhere around it
    • Engine turning over but not starting.
    • Just checking, does the engine turn over and not start? or is it just a single click and doesn't turn over at all?
    • Hi SAU family, having issues with my R34GTT which is slightly modified and tuned to e85. so scenario is, I’m driving the car to work (30km oneway) and then coming back in the arvo. Car starts and runs fine in the morning and on the way back home (in the arvo). I stop the car when i gets home and after 10-15 mins, it wont start. Battery is fine, fuel pump seems to be working. All i hear is engine clicks but wont start.  Last time, i disconnected the battery terminals and re connected them. Check fuses. Didnt start at that time but started after an hour (so I say when its cool down). Mechanic cant find the issue as its running now and nothing coming up in the diagnose. any advice,opinion or anyone gone through similar issue.   thanks 🙏🏻
    • 9" +35 will rub on the suspension. R33 GTR wheels are +30.
    • I know a guy with 18x9 +22 on the front of a 32 gtst, needed quite a lot of guard work, tyre stretch (215) and camber. Not sure what your current set up is, +35 won't be as much, but still a fair bit of guard work and camber.
