Ladies.
Went to russell island today for an onsite. Missed the ferry on the way back and had to stay there for an hour and a half with nothing to do.
Cost me $110 to get there and back though! I considered swimming then I realised how much of a distance it was and how unfit I am. Now that I think about it, I probably couldn't even swim through that.
12 hours worth of pay for it though, should be good.
Q:
Z32 afm and the plug to suit ecr33 will it work without a tune?
f**k Russell Island. Went to a house party there one night because I thought awesome a party on an island it will be the bomb. Think again f**kface, that place is like going back in time. f**kin hellhole.
Anyone in here good at maths ?
Can someone tell me how to simplify :
square root of 3 to the power of 3 ?
Pretty sure its 3 x square root of 3. Something along those lines.
Sup mangs
Morning Mangs
Lowball forum down :D Nothing to moderate
Also, my database server shat itself on the weekend. Wonderful start to Monday morning :blink:
For John: ISO14 is available!
sqrt(3)^3
=(3^0.5)^3
=3^(0.5*3)
=3^(1.5) or 3^(3/2)
Took me 5 minutes to work out what you were talking about. I was wondering what device I used that I could update to ISO.14... and then didn't know what ISO.14 was... Needless to say, I failed terribly at recognising what it was meant to be.
Alyssa got it straight away though... so maybe I'm just still half asleep?
Good Day y'all
Lakeside Open Sprints - Sunday 29th August. Get amoungst it. I don't want to be all alone
I would but the car is far from being track worthy. Let me have a steer? :banana:
You pay per driver, so no.
However, if they do passenger runs at the end of the day I can take you for a spin. Bring a helmut
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
