Miss me?
<3
Dear Tristan
<3
Martin
its like me but dif wheels + skirts!
martin i trial fitted a 32 GTR front lip on the 180
will make the front of the car less than 20mm from the road
will have to cut the lip in the middle to shorten it by 40mm or so - its too wide
not sure if i have big enough nuts to rock it though
do it!
I just got my work monitors upgraded to these: http://h10010.www1.hp.com/wwpc/us/en/sm/WF...71-1815933.html
OMFG sexalicious. I might have to buy a couple for home now
I prefer 4:3 for basically EVERYTHING except watching TV/movies.
Thinking about it, I really need one 4:3 and one widescreen, but both must be 1200 lines and both the same height.
That samsung is only 1050 lines, epic fail :P
Will we get to see these borrowed wheels tomorrow?
and hi! :P
Not sure on that, Anna doesnt want to eat icecream because she feels bad about missing the gym, but i might come along anyway, especially if Noel goes cause i need to talk to him anyway!
Drive me. I'll come to Yeronga
She could have a fat free sorbet :P
I know they still have sugar in them... but better than fat and sugar together!
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
