Miss me?
<3
Dear Tristan
<3
Martin
its like me but dif wheels + skirts!
martin i trial fitted a 32 GTR front lip on the 180
will make the front of the car less than 20mm from the road
will have to cut the lip in the middle to shorten it by 40mm or so - its too wide
not sure if i have big enough nuts to rock it though
do it!
I just got my work monitors upgraded to these: http://h10010.www1.hp.com/wwpc/us/en/sm/WF...71-1815933.html
OMFG sexalicious. I might have to buy a couple for home now
I prefer 4:3 for basically EVERYTHING except watching TV/movies.
Thinking about it, I really need one 4:3 and one widescreen, but both must be 1200 lines and both the same height.
That samsung is only 1050 lines, epic fail :P
Will we get to see these borrowed wheels tomorrow?
and hi! :P
Not sure on that, Anna doesnt want to eat icecream because she feels bad about missing the gym, but i might come along anyway, especially if Noel goes cause i need to talk to him anyway!
Drive me. I'll come to Yeronga
She could have a fat free sorbet :P
I know they still have sugar in them... but better than fat and sugar together!
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
