That was me. My AFM has been a bitch lately. I cleaned it and the plug so many times and I just couldn't work out what the problem was!
Got it sorted now though, it was the secondary connection on the strut tower (which I didn't realise it had!!) that was full of sand and dust and shit. Pulled over and flushed it with WD40. Was that you going past in the silver 33 giving a big turbo vent salute? :happy:
....ok so maybe it wasn't that. I'll swap the AFM tomorrow and see if that helps.
No idea yet. Will be looking for a suitable spot to go this week. There are a few cold rocks around etc but I dunno what the talent is like. Gold Coast is usually pretty good though.
Cold Rock is fail.
QFT
Gold Coast girls are also fail. They're coked out and worn out.
My favouuuuuuuuurite
Cold Rock is fail.
Cold Rock is good. Coast > Brisbane.
Well, I put it to you Sir...that you sucked off a horse.
Mangs,
Sunday night blues again. Trying to consume my bodyweight in bourbon and pretzels
For some reason I bought a set of iridium spark plugs on sat, only to realise that I have a set in the garage that have only done 10,000k. :facepalm:
So I have a set of new or a set of used spark plugs do sale.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
