That was me. My AFM has been a bitch lately. I cleaned it and the plug so many times and I just couldn't work out what the problem was!
Got it sorted now though, it was the secondary connection on the strut tower (which I didn't realise it had!!) that was full of sand and dust and shit. Pulled over and flushed it with WD40. Was that you going past in the silver 33 giving a big turbo vent salute? :happy:
....ok so maybe it wasn't that. I'll swap the AFM tomorrow and see if that helps.
No idea yet. Will be looking for a suitable spot to go this week. There are a few cold rocks around etc but I dunno what the talent is like. Gold Coast is usually pretty good though.
Cold Rock is fail.
QFT
Gold Coast girls are also fail. They're coked out and worn out.
My favouuuuuuuuurite
Cold Rock is fail.
Cold Rock is good. Coast > Brisbane.
Well, I put it to you Sir...that you sucked off a horse.
Mangs,
Sunday night blues again. Trying to consume my bodyweight in bourbon and pretzels
For some reason I bought a set of iridium spark plugs on sat, only to realise that I have a set in the garage that have only done 10,000k. :facepalm:
So I have a set of new or a set of used spark plugs do sale.
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
    • Well, I was using ECUTalk software if that helps? Not sure if that only can see engine codes? Is there any other software I could give a try? Or any way I can get a blink code?
    • I never touched it, it should have. I'll try to give it an adjust. With IACV plugged in, it idles at around 1120RPM on average. Max 1200 RPM, Minimum 1025RPM before it starts dropping right before stalling. Took the data from the Nistune logs.
    • Thats what im trying to solve bro  no one with aem tuner experience would advice  much appreciate
