Sup mang. Me to :banana: we got beaten like 9 - 5 or 9 - 4 though :bunny:
We won like 160 to 20 :bunny:
Played the team at the top of the ladder too :)
one of them colin, nice goal you smashed through. tristan got a good one too
Does Tristan still love us?
no more tractor for now, she is doing a course next year that costs 10k so its going towards that instead, Anna will drive my car, I hardly use it anyway
what-the-shizz? the impactblue car is going?!
Martin - Can you please post a photo of my speed sensor? I have a dude that might have one for sale, he just doesn't know what it is, and a description of "It's a forked cable that plugs into the rear diff" didn't help him at all...
Morning Mangs!
That's what she said.
Yeah mang. I want pics from saturday but I havent seen any. I am disappoint.
ill always have big love =]
<3
Well I'm lost...
Best I could do at 6AM before work:
saturday night drunk martin, colin and joe removed the wheels from the TRD mazda and waited for the lulz
I was sober. Lulz were epic though :)
hahaha nice one
still waiting on photos lol.
+1
Look, she's out of the kitchen, there are bright lights flashing at her, she was confused
The interwebs is not as easy to manoeuvre as a sammich
sig'd :thumbsup:
yeah, you guys should be nice to random girls on the internet
...at least untill you meet them/get pics and determine if they are hot JB or not...
Agree 107%
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
