Personally i would prefer good wet weather braking over good traction in the wet.
Why not have both! Braking in the wet at traffic speeds is only gonna be as good as your front tyres!
I hearya dude. both is great but i become miss daisy when it rains. Traction even in the worst conditions will not be an issue to me.
Lol,
Seems to be a right royal clusterf*ck at work today. Email Down, Internet Down, Document Management system down, 90% of all other systems down.
Glad I didn't make it in, somebody else's problem :thumbsup:
Edited by Smity42
Too much wet this weekend. Garage got 2" covering and it almost came inside the house :thumbsup:
I put some oober drainage out the front too..... stupid thing got blocked between the street run off and the drains I put in... grrr.
Yeah, Rain is good, the grass seed we threw out last week is about two inches long, but at the moment 70% of it is under water. I think it's drain digging time, when it finally stops raining on the bloody weekends.
I just have more weeds growing :thumbsup:
And haven't been able to mow for weeks
havent had to mow a lawn in like 18 months because of the horses lol. That's the only thing they're good for.
Apparently they taste good too.
Lol,
Well, we just had people bring in old crt monitors asking why they werent working. The things were filled with water because they left the window open :\
My coon's brakes arent too fantastic, they shudder in the dry (even with new rotors/pads) so it's a good thing I only had to drive to aspley and back this morning and then 5 minutes to work.
I was thinking about how awesome it would be to have awd today, getting up a hill with t/c on wasnt fun.
It's raining fuccking sideways!!!
Lol, I opened the garage door this morning, saw that, and instantly thought of Forest Gump giving a breakdown of the different types of rain.
sup mangs. Scored a full exhaust for the GTR. Front pipes, cat, and 3 inch catback with canon for $220. Bargain.
by scored, is another member going to start a thread in a few minutes saying "some cunt stole the exhaust off my r32 gtr."?
today's drive to work was great fun. No one on the road cause you couldn't see more then about 20 metres in front of you this morning
I had eleventy billion people in front of me today! How come you got so lucky?
for noel
The Exige Type 72
The Exige Scura
Which are all the same as these - Exige Cup 260
All 260Hp 2ZZ-FE toyota supercharged engines, the only real difference is the Type 72 runs Bilstein/Eibach suspension and the Scura and Cup 260 run full Ohlins external cannister race suspension. All of them are around 900Kg on the road.
Edited by Dan_B
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
