Yeah I figured, thanks for the offer though mang appreciate it!
I'm thinking the cheapest way out of this might be to buy a new (wreckers) hub.... Dan gave me a quick run through on how to swap the hub over but I might look it up, see if there's a guide on here somewhere
Twas a good night. So good, I fell out of my chair....face first....towards the fire....didn't spill my drink though!
May have had something to do with the lid being on :)
P.S.... Hot Ranga bird is alright :-) She holds her pose well.
Edited by SABBAi
Who puts lids on fires these days... I mean really.
It's an outrage!
Too 'spensive :)
Plus they'd probably give me a piece of finger boy's car just to spite me
col pics provided lolz
I am dissapoint. You'd better be there Thursday mang
There would have been MANY MANY more lolz if you had attended tristan.............just not for you :)
Sup mangs,
Uni presentation this morning. Winged it. Went pretty badly for the first part. Nailed the ending. Am a little disappoint.
That's what she said
Morning mangs
Well done Col, least it's over now eh :woot:
Yeah just got to finish compiling the assignment. Retards in my group left me with all the formatting and submission. It's a dogs breakfast, so lame.
Well done Col, least it's over now eh :)
Dude, that is the bitch's job.
Srsly, we used to give the girl all the formatting and submission crap in group assignments. Obviously since women should be in the kitchen and not doing engineering degrees, we couldn't trust them to do any of the engineering work. So we would do that and give all the bits to the chick to assemble into a submission. It's basically the same technique as making a sammich, so they're pretty good at it.
no bitch's in construction. And the rest of the group are droolers so I think it's best that I do it. This is the most I've ever contributed to a group assignment. It sucks when you actually have to organise people and do the work aswell. So f**kin lame.
Listening to Europe on uni computers. Very appropriate for assignment that is due for submission soon. 'It's the final countdown!"
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
