Mangs. See you all this afternoon.
On a side note, what's everyone's thoughts on monza bucket seats.
Option 1 have an ADR compliant fixed back one that I am considering instead of velo.
Comments, thoughts, insults?
Comments?
Monza stuff seems to be getting better, although it is not as good as the more expensive stuff obviously. Seems to be quite decent and good value gear.
I'm probably going to get Monza harnesses for the alfa.
thoughts?
Thinking has been suspended for the remainder of the day, and most likely for the remainder of the week as well.
insults?
You're a useless serb.
Think about it mate. i will be there in alvin. she'll go farken nutz tryin to get at me.
It's not rape if she's begging for it :P
Only comment is that a fixed back in a 2 dorr is illegal regardless of ADR, If you are cool with that I say why not!
Yeh, as Col said, going the 2 seat route anyway, so will be getting it mod plated and registered as a 2 seater. Going one fixed back drivers seat and one gtr seat, with kind thanks to Noel, so I can still have easy access to the back area without having to remove a seat.
I popped in today and had a look at it. Looks good. ADR approval on it, and most impotantly, I fit in it, unlike Bride and most Sparco seats.
Link for any other people interested or that want to have a look:
http://www.boostcruising.com/forums/index....howtopic=641160
They are out of stock till November though
Speaking of which, i should have my car back this weekend Miso, should be able to hook you up any time there after.
As for the monza, TJ33 has one in brand new condition, I sat in it the other night and was very surprised at how comfy and supportive it was. Its for sale pretty cheap too. Silver in colour. different but nice.
All of those seats look pretty good!
Too easy, cheers.
TJ33, is he a member on here, with that nick? might pm him and have a look at it.
lol, i got some issue in my car, thinking its a blocked fuel filter. Car just has a sluggish pickup under load...
meh, i'll change it on saturday while i drink
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
    • Unfortunately the cavaet to that is that while any scan tool should be able to read the code, the workshop will need a consult plug to OBD socket adapter. You don't have a location on your profile, where are you based?
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
