I realised this morning that I took the locking wheel nuts off the pig and put them on the GTR and forgot to put some normal wheel nuts on in their place. So I've been driving the 31 with 12 wheel nuts instead of 16. Should be right eh?
Morning Mangs,
Wow, I swore they were singing about the Pontiac G6 in the song...
Thank you wikipedia... you have left egg all over my face again...
Who would write a song about a heap of sh*t holden?
proud new owner of a black r33 gtst skid machine.
shall pick her up tomorrow.. mods start thursday :)
How do you do skids in a boat? :)
Jokes mang, congrats.
Nice ones. STL!!!!
Sarp mangs. In on page 700.
Of how many?
Yeah she'll be right. Thats too many wheel nuts for a 31 tbh.
lol great minds..
:) Marry Me? :)
morning post!
i'm having a 'stray'n day today to replace the fuel pump. Hope that will fix the 31
Edited by Smity42
morning post!
same here. couldn't swing a day off on my birthday, so instead having one today.
got the new call of duty, so will spend the afternoon on the couch.
Of how many?
Of 700 :blink:
Yeah I thought that too. It's alright though I just put them on hand tight and then backed it off a few turns :unsure:
f**k it she'll be right
31 Love
morning post!
Nice Mang
On PS3? I really need to buy more games for the PS3 but I hardly use it as it is...
Of 700 :cool:
:unsure::blink::P
Yeah I thought that too. It's alright though I just put them on hand tight and then backed it off a few turns :devil:
Perfect! Glad to see someone doing it right.
31 Love
<3
Nice Mang
As Marty said, too many
my daily now has headlights, highbeams, a working horn and parkers
go me
Pffffffffft too much for a daily
go me
:unsure:
Are shocks for 2 door and 4 door R33's the same? I'd assume they are?
Yep 100% the same*
*This information may or may not be correct. The public are warned not to take any advice from a Ranga Pom. This public service announcement has been brought to you by British Petroleum.
Anyone want to by a 31?
Don't you mean "Dependable Petroleum"?
I find your lack of 31 love disturbing... :unsure:
Give you a carton for it.
What you gonna drift?
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
