Lolwut?
I saw that on faceparty and approved. Then I read up some of the stuff winphone 7 doesnt do and was extremely dissapoint. Reminds me of the original iPhail :( . Hope they fix it with some updates.
I am surprised it does not work with vista though... although vista is pretty sh*t.
Vista is pretty gay. It says I need Zune to get updates and put music / movies to my winphone BUT Zune says I need service pack 3 for vista. I googled it and it looks like there isn't a service pack 3 for vista. Weird.
Side note :
Go the POMS!
Lol. Good form microsoft.
Side note :
Go the POMS!
</3
Haddin is a hack behind the stumps. Leave him in the team as a batsman and get T-Paine in to keep. Drop north.
he isnt a good enough batsman for that, would be a waste of a batting spot.
drop North Hussey and Haddin bring in Furgusen, Paine and Hughes, move Watto to middle order.
He's certainly better than north.
I'll agree with north unconditionally. He is DEFINITELY a waste of a batting spot.
No need to move Watto down, his performance as an opener is WAAAYYY better than it ever was down the order. If he starts underperfoming then consider it.
Hughes has performed at state level but i've only seen him choke in tests. No spot for him in my team.
Hussey has won test matches (and series) for us many times before. I'm prepared to leave him in for at least this series. He needs to be down the order more though, he does a great job finishing the innings.
I like Ferguson, I'll pay that.
Haddin, North, out, Ferguson, T-Paine in. Hussey down the order.
Watto is the perfect middle order batsman though, can tough it out or attack as required. At some stage we will end up back there because at the moment he isnt being used to bowl to close out innings even when on fire because they need to keep him fresh to open.
PS Having him on your highschool team was so very very helpful lol, wasnt allowed to bowl then though
A valid point. Need a genuine opener to fill the spot though, and for me it isn't Hughes.
LOL.
Speaking of watto, nice catch. First test wicket for X-Man too. Now hurry up and get the last one.
good morning gents, i just awoke
That's what she said.
Damn it didn't see that coming.....
How stupid are people ? I mean really. I requested that the caller ID be turned on so that people can see our number. The response I got was ;
"Please note, in order to access the "missed calls" feature, you will need to instruct your users to press "Directories" and then select the "Missed Calls" option.
Should you have any questions or issues relating to the service please contact the Optus Service Desk."
So we can see the calls incoming now... stupid.
Side note :
Got the zorst raised today. Was told that I could go higher if I got rid of my drager and got a 4 inch hotdog with a tri-flow cannon which are slightly smaller. Anyone heard of the tri-flow ?
i hope so....but seems unlikely
What I've seen of him so far has been good, but to be fair I didn't see any of his overs during the day today.
Are they going to have to bat this arvo or not? Nine has stopped coverage. f**kers.
he may play well for a time while he is in form, but in the fair dinkum department.....he averages close to 50 in first class with the ball, thats pie chucking in anyones language. And he is already 28 so some massive improvement isnt likely
Haven't heard of it/them, no
Martin what's your thoughts for a meet spot tonight? I'm stopping in the city to see Tristan for a bit then heading to wherever?
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
