Martin f*cking lol at that thread. If old mate pays more tax then you earn a year i think he should throw me a couple thousand to play with too.
Ravi, baked beans can pressure tester sounds like an awesome tool, air leak anywhere in the pressure side of the system will cause you issues. The other way i have seen for checking for boost leaks is pretty dangerous, it involves removing bonnet, a back road and holding on tight.
Edited by Dan_B
I think Noel is definitely a better Troll than me...
Keen.
HAHAHAHA I feel like we should try that method
f**k I love skylines. I was down the back end of the warehouse and I heard out at the street the biggest, fattest spool, screeching of tyres, screamer pipe, EPIC atmo bov... and run out and she was gone :( ... but was definately an RB :worship:
just replaced the rear shoes and brake cylinders in the parents car, it shows i don't do much with drum brakes, took me 3 hours to do it.
urgh cant seem to multi-quote with the mobile forum, fail.
@Dan:
A - drums are shit.
B - you had plenty me practice on the xf, should have been able to smash it in minutes.
@Ravi: that's what she said.
@Miso: tfif +11ty
Yeah the iphone version of the forum is severely lacking key features
-Page numbers
-ability to multiquote
-tits
We can fix the last one easily enough
Carpark meets with dodgy folks.
Defected for not being one of the miniorities.
Still have the same defects on my car currently. Couldn't be arsed to get rid of them yet. I've grown attached to them <3
Morning peoples.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
    • Not yet quite as bad as what we've seen a Jim Berry clutch do in an R32 GTR though when it decided to cut a chassis rail in half... Still very very gnarly and a great reason to avoid.
