Anyone know the size of the throttle body rubber/silicone joiner on RB25det? is it 70mm diameter? by about.... 4 inches long??
Got a split when I changed the turbo... replace it and see if there's any improvement
Public holidays are 250%
I will have fun basically rewiring my car ! LOL
Took tonight off as I'm working strayan day.
What is up with you mangs ?
work on straya day n get the double time pay then take the Thursday off instead? Sounds like a solid plan to me. Profitable aswell.
Now that is strayan thinking. Nice work!
I was going to wear and aussie flag as a cape and beat up minorities. Anyone wanna tag along?
Seriously though. BBQ somewhere?
f**k yeah. Keen to beat up some injuns.
To you? Probably.
I can't help it if she doesn't like mario brothers...
Anyone go to Lakeside yesterday? Went out for a few hours, saw all the cars but standing in the sun being roasted like a lobster got old quickly.
Didn't know it was on.
big thumbs down for working a strayan day though. Wait ? Is it really a strayan day? I thought strayan days were chucking a sicky to go fishing and such like. Hmmm... me thinks this could be a fake strayan day.
*HEADSPLODE*
Truth.
Sure you don't want to get a southern cross tattoo or something instead? :thumbsup:
Any one seen any R32 GTr brakes for sale recently? Just wondering what they are worth!
Swaps for a garage door?
HI
Hi :action-smiley-069:
$300 - $400 for callipers and rotors off the top of my head. they are roughly the same size as r33 gtst brakes.
Mangs.
At band practice. Band still not here. Lame.
Make like a bass guitar and be inaudible.
Have hit a brick wall with guitar. Haven't found anything interesting or challenging to play, and if it is challenging it's way to hard.
$475 for DBA rotors.
Have a set of them on the coon and they go alright for pulling up a barge. Better than factory anyway; bit more reassurance when heavily braking down a hill.
Ravi: A split at that connect would most likely be causing you an issue. As for what i have for sale.... uh 33 parts? Diff, Nismo clear side inidicators, and a S1 RB25DET ecu. Thats all i can think of at the moment.
straya day plans?? im really keen just to drink somewhere.
John, should be more awake in the mornings, if i see you again expect epic alfa horns from my skyline
Traffic is blocked off due to a fuel tanker trying to drip around a motorway feed ramp..... obvious occured. tanking pancaked and dropped it's load.
