The only reason I would ever be in uni at 8am is for an exam. If there is a lecture before 11am at uni I wont be at it.
Another successful theft from McFly.
Damn, we give you a lot of business.
Also, the receptionist at Powerlink is cute.
The reception chick changes all the time. I don't think they have a dedicated reception girl, I think that all the admin girls from around the business have to take turns manning the reception.
However, based on your hot tip I made an excuse to go to reception for a perv. Definitely very nice, I haven't seen her before.
Work location please I need to go visit your receptionist, our receptionist is fake tanned scary person.
She's been there the last two times I've been there :thumbsup:
Repetitive computer processes are teh ghey.
Automate that shiz.
Sucks to be you.
I just went back and the older bird was the same, but I am 100% certain she is not the one you were talking about.
There was a DIFFERENT young chick with her, who was also pretty cute.
Going to hit faceparty hard tonight with a few names out of the phone book to see if we can solve this mystery..
lets ALL go there and park our skylines outfront.
Get your own hot receptionist. These ones are mine :devil:
I have this cool idea, Instead of being a creepy stalker walk up to her and say hello im Martin (the stalker) hows it going, whats your name. When you talk to chicks sometimes you can find out amazing things! Like thier name for example.
Same younger chick both times. Not the old bird.
And I spotted her first. Twice. So she's MY hot receptionist.
Stealth lessons.
Sign up for them.
wow this thread isn't creepy at all :wacko:
There's not one female employee here, lame.
I've worked in an all male environment before and also in a place where I was the only guy. I'll take the sausage fest any day, MUCH less bitchiness and much more lulz.
Unless all the chicks are hot... Then I'll work as the only guy once more!
Tell her there is beautiful forestry that is about to be turned into a Dam and therefore flooded, destroying the beautiful area for ever.
invite her on a canoeing trip to experience the glory of the forest one more time.
Burt Reynolds ?
Profit
That's Crazy Talk!
HAhahahahah I love that idea
This thread has ALWAYS been creepy
I work with 3 other guys, the boss's wife, and that's it
+1
That's Crazy Talk!
C'mon guys, Martin isn't known for the balls out approach! I seem to remember pussing out when I was trying to hook you up with my (now) missus hahahahahahahahahaha
Missed the boat there buddeh
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
