I'll see how I'm going tomorrow before I make a decision re: German Club. Might be too tired.
Finish work at 4am, car has to be at Fulcrum to finish the suspension work at 8am. I've been up since 6am today so 22 hours awake with a 12 hour shift at work, three hours sleep then car off to the workshop. At least I'll have no more rubbing on the inner guards, no more bottoming out and f**king my front bar as well as new adjustable camber arms :)
Now I just need confirmation from Chris Rodgers for the stero/GPS work and then I can get the exhaust leaks sorted. I swear I'll get it up on a dyno soon...
Calvin harris tomorrow !
Ahh! Someone here other than me also likes 'electrophaggotry' hahahaha
Half considering going but with soundwave on saturday I dunno if I can justify heading out tonight
Anyone need guards rolled? I need some more beer..
If the suspension work I'm getting done today doesn't eliminate all the rubbing on the guards I might need them rolled/inner guards modified. Will have to wait and see how it goes.
I swear I'll get it up...
That's what everyone says.
Turbo is on the way, he posted it yesterday.
Apparently he sends them COD and you just pay at the post office. Easy enough I suppose.
Probably won't be there today though :(. Next week.
Man, I was feeling all happy as I'm about to go pick my car up. Now I'm feeling all down.
So much respect and admiration for anyone who helps out when it all hits the fan, where ever that may be. It must be so difficult to deal with but I'd feel worse if I could have helped but didn't.
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
