Where do people get their licenses from? I nearly got hilux'd this morning crossing the road. Farrk
Same place the Asian chick in a white Getz I saw on my way to work did. She turned left while indicating right... WTF!?!?
Morning Mangs
Yet to be pulled over, or even had a second look. Could be due to when and where i drive, but i think its mostly because the car's bog stock.
I don't get pulled over too often, do get looked at and followed a lot though.
Can some one give me a playing contract so I can go out and muck up and get kicked out of the club. Oh and still get paid out $1mil on leaving.
I will give you a $1/year contract to play the banjo. If you muck up and get kicked out of a club, termination payment will be $1.
Only catch is you have to be good at playing :thumbsup:
That's what she said
Sarp mangs. Sore throat is not so sore. Winrar!
Did the lube help?
fark missed a page :(
3rd last day today. Ducking out early however :)
I'm a big fan of ducking out early
hai guys :action-smiley-069:
so much ot do this week again....
McMarty, get the rom off the board yet?
hai Scottai. Nope, too hard. Did you buy the special tool thingo you were talking about?
Wheat Bix packets. Getting hilux'd can't be good.
*headsplode*
It comes with the car I'm guessing...
I've seen this all too often
Heading down to Jaycar this arvo. Or if you're not fussed on keeping the standard ROM, cut the legs. It will make it hella easy.
Throw in a piece of straw and overalls, and I'll start negotiations with the sister/wife.
hyuck hyuck
They don't. They spend all their money on $100,000 cars with custom plates and forget to buy driving lessons and indicators.
For sale, one set of BMW/Merc/Lexus indicators. Never used, current owner is stuck so far up their own ass that they think that everyone should give way to them automatically in all situations. Will swap for in car entertainment system so I can be even more distracted while running the kids to school.
  • Like 1
That's what she said.
Out of curiousity, link to said tool at Jaycar?
I couldn't care less about the the stock ROM. I did think of cutting the legs off, but my side cutters don't seem to be able to manage it :(. I might trying going in from the 'top' instead of the 'side', if that doesn't work I might just get the dremel out...
hyuck hyuck
A piece of straw I can maybe manage but overalls? C'mon man, I drive a 31... I can't afford overalls.
If I bought a $100,000 car, I'd want it to come with indicators. Just sayin...
I'll give you a fish tank and a mountain bike inner tube.
3.5 hrs
Impressive.
How do you blind an Asian?
Put a windscreen in front of her
No idea on the link. Just gonna roll down there and hope for the best....
I was trying to keep the ROM intact!! If you had of said not to worry, I would have cut the legs off it!
+1 cut legs off with dremel.
Or you can use a heat gun on the reverse side but you need to make sure you concentrate the heat onto the rom and not the surrounding chips
Furry muff... I'm just keen to see what sort of tool you have in mind...
Dow! Communications breakdown :(. If I give it back to you on tursday and tell you it's OK to cut the legs off, how soon can I have it back finished? :)
A supporting vote from the allmighty Dan? Sounds like a goer.
Not so keen on that technique... i'd cook something else for sure...
Annoying thing is I've desoldered heaps of ICs before just using my soldering iron and a solder sucker... this one's just being a right prick for some reason.
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
    • Unfortunately the cavaet to that is that while any scan tool should be able to read the code, the workshop will need a consult plug to OBD socket adapter. You don't have a location on your profile, where are you based?
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
