Where do people get their licenses from? I nearly got hilux'd this morning crossing the road. Farrk
Same place the Asian chick in a white Getz I saw on my way to work did. She turned left while indicating right... WTF!?!?
Morning Mangs
Yet to be pulled over, or even had a second look. Could be due to when and where i drive, but i think its mostly because the car's bog stock.
I don't get pulled over too often, do get looked at and followed a lot though.
Can some one give me a playing contract so I can go out and muck up and get kicked out of the club. Oh and still get paid out $1mil on leaving.
I will give you a $1/year contract to play the banjo. If you muck up and get kicked out of a club, termination payment will be $1.
Only catch is you have to be good at playing :thumbsup:
That's what she said
Sarp mangs. Sore throat is not so sore. Winrar!
Did the lube help?
fark missed a page :(
3rd last day today. Ducking out early however :)
I'm a big fan of ducking out early
hai guys :action-smiley-069:
so much ot do this week again....
McMarty, get the rom off the board yet?
hai Scottai. Nope, too hard. Did you buy the special tool thingo you were talking about?
Wheat Bix packets. Getting hilux'd can't be good.
*headsplode*
It comes with the car I'm guessing...
I've seen this all too often
Heading down to Jaycar this arvo. Or if you're not fussed on keeping the standard ROM, cut the legs. It will make it hella easy.
Throw in a piece of straw and overalls, and I'll start negotiations with the sister/wife.
hyuck hyuck
They don't. They spend all their money on $100,000 cars with custom plates and forget to buy driving lessons and indicators.
For sale, one set of BMW/Merc/Lexus indicators. Never used, current owner is stuck so far up their own ass that they think that everyone should give way to them automatically in all situations. Will swap for in car entertainment system so I can be even more distracted while running the kids to school.
  • Like 1
That's what she said.
Out of curiousity, link to said tool at Jaycar?
I couldn't care less about the the stock ROM. I did think of cutting the legs off, but my side cutters don't seem to be able to manage it :(. I might trying going in from the 'top' instead of the 'side', if that doesn't work I might just get the dremel out...
hyuck hyuck
A piece of straw I can maybe manage but overalls? C'mon man, I drive a 31... I can't afford overalls.
If I bought a $100,000 car, I'd want it to come with indicators. Just sayin...
I'll give you a fish tank and a mountain bike inner tube.
3.5 hrs
Impressive.
How do you blind an Asian?
Put a windscreen in front of her
No idea on the link. Just gonna roll down there and hope for the best....
I was trying to keep the ROM intact!! If you had of said not to worry, I would have cut the legs off it!
+1 cut legs off with dremel.
Or you can use a heat gun on the reverse side but you need to make sure you concentrate the heat onto the rom and not the surrounding chips
Furry muff... I'm just keen to see what sort of tool you have in mind...
Dow! Communications breakdown :(. If I give it back to you on tursday and tell you it's OK to cut the legs off, how soon can I have it back finished? :)
A supporting vote from the allmighty Dan? Sounds like a goer.
Not so keen on that technique... i'd cook something else for sure...
Annoying thing is I've desoldered heaps of ICs before just using my soldering iron and a solder sucker... this one's just being a right prick for some reason.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
