There is no way I am going to go and eat icecream, outside, in single figure temps. That to me defines silly.
^^Skirt.
It hasn't even hit single digits on the big a*se thermometer there yet anyway.
So uber turbo has been paid for and will be built this week. 350hp+ atw in a sub 1100kg car.... Bring it!
I hope I can make that much in my 32 when it's finished. I picked up my block from Chiltons this morning, just gotta put it all together now and port the head. I'm hoping my 4 year old $100 225/50/16 tornados will be adequate for traction
Thats pretty exciting!
Those tyres should hold.....at idle
Morning Mangs,
TFIF.
Ikes Cream meet was good, Andy is a skirt - it only got down to 11 degrees.
Drama towards the end as 2-bob, 5-quid, and douche got reversed into in the carpark as they were leaving. :(. Hope insurance doesn't give you any trouble, let us know if you need witnesses.
Final thought: Hail to the King, baby!
WTF are you on or about on both counts Smitz ?
Count the first: On or about the 9th of June, 2011, one twocents, while driving a car owned by his girlfriend, five-quid, and with overly exciteable passanger the mighty douche on board, was struck in the front right quarter panel and drivers side door by a silver Honda CR-V who decided to reverse straight put into them. Details were swapped, quarter panel was bent to allow door to open and the mighty douche continued to dance around in excitement over his purchase of an auto loading pipe.
Count the second: After a development time longer than the time between "we will have a man on the moon by the end of the decade" and "That's one small step for man..." Duke Nukem Forever is finally coming out. Nerds everywhere have had a collective orgasim.
Seriously, Duke forever has taken longer to release than the foundation of the Apollo missions to success with Apollo 11. The Beatles formed, recorded all their albums and broke up in less time than this game has been in development. While this game has been in development multiple wars have broken out and a few have ended. Britney Spears' entire career fits inside the development window of this game. It took them less time to build the channel tunnel than this game. It better be one genre defining game is all I can say...
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
