Particularly now that the general instability has gone (well, give it a few weeks for this to blow over) i think you'll find gold is actually a pretty bad option. Though you've done well in the last few years, on average it doesn't seem to go up as much as the share market does, i think.Or something. i'm not a professional.
when the share market goes bad gold goes good
Morning Mangs,
Hey, McFly!..
...yeah
Looks good!
Wheels don't look multistud though
Me likey!
That's what she said.
Throw in a cat with helmet cam. :thumbsup:
LOL! Don't have a cat, or that would have been an awesome plan
Moaning ho's.
Might take apart the cross over pipe today and replace the valley cover.
That or I might spend all day on the couch.
Ah, the agony of choice. What happened with those 2 jobs you got offered?
R34 is apparently a bit harder due to TCS, etc.
Bored.
Need nets, saw my old batting coach. Need to practice this new stance and 'trigger movements' that will apparently get me back on track fast.
Will you be around this weekend?
Batting coach. Need one of those.
Yeah should be.
I found mine from back in the day. Had a quick catch up.
Cool I will be in contact and see if we can organise somthing. I will see what Gerv is up to as well.
    • 21 is explicitly the coils detected as the issue. Is it guaranteed the actual issue? No. Just the ECU thinks it is. When you say rattling, describe it better, get an audio clip as best you can if possible.
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
    • Yeah thats the plan now. 🤞
