Here you go Scott.. took me 4 hours of pissing about getting everything lined up and looking good. End result is exactly how I want it to be
I'm happy it looks good on the car!
Mangs. Scrackin?
Oloha Osola :thumbsup:
BTW John, I'm currently sitting about 12 feet from Cassie... maybe she's transferring to IT :):ph34r::bunny:
Is she mcHawt or something?
I just took delivery of a 2012 mustang... the fun begins - now.
I'm really not a fan of them. What's the build quality like?
okish in LHD I think when they swap sides a lot of it is up for debate.
Thats like the italians, wiring diagrams are accurate for the LHD model, RHD its whatever wire they got lying around, and extra connectors
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
