Sarp mangs. Extended absence from here since work have the audacity to make me work while I'm there...outside pirate.gif. Cheers for all the birthday wishes...I think. Rangas get birthdays based around the leap year. Normally the year before, year of and year after the leap year. Just to clear up any queries. How's the weekend going? I ended up hammered on Friday motorboating many boobies at the Cabaret club and Love n Rockets and it was all paid for cheers.gif Great success.
Nice one Colin. Sum of my weekend.
Happy laps was awesome. Gokarting was also awesome. BBQ was awesome. Damo breaking all my shit was not awesome. Doing nothing today was awesome.
This seems to be a common thing when SAU guys come to your house, we break shit. sorry i couldn't be there, had other things on.
Anyone want a free R31 shell? straight car, tiny amount of surface rust. Free come pick it up. Get free shit. Colin?
If only it was a wagon I would take it.
Morning Mangs,
Shut up, Vettel.
:P
Sarp. Me too :(. That's far too many birthdays. Weekend was good, not as many boobies though :(.
Happy laps was awesome except for:
A) Brakes not working (expected)
B) Air fuel guage not working :(
C) Clutch slipping :( :( :(
Go karting was awesome. Might have to re-asses my opinion of Kingston park, maybe I just got the shit blokes last time.
BBQ/Drinking was also good.
Drive home was too long :(.
Putting new brakes in yesterday was not fun, but at least it is done now :). Also fixed Air fuel guage.
Bled the clutch while we were at it too, because the fluid had aids. But I give that a 0% chance of fixing anything.
Nice one Colin.
That's what she said.
shit bloke, that guy. Hope you had a good day/night other than that :thumbsup:
He was not even an SAU guy
Bros b4 hoes Dan.
Double the wagon love.
i think you should still take it anyway.
I thought it was meant to be your track car Dan?
You'll never guess it; he changed his mind again. He now wants a faulty chassis.
Go kart videos are uploading now, will link them when they are done. I forgot to put the spice girls music on them for Scott though :(.
Will try to get the happy laps one done tonight. Maybe that needs some spice girls...
Wow really? Dan changed his mind?
a fiver says the faulty chassis never happens
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
