The only real problem I've ever found with them (overheating wise) is if you use aftermarket seals. Then they leak oil, and then get too hot because they don't have enough oil to keep them cool.
Insufficent lubrication. Never good.
Mangs, scrackin?
Had an epic lazy weekend, apart from the going into work on my Saturday off, making up for that now by screening all works calls they can eat a dick cheers.gif
GL to you john but all my years of not owning an aircooled engine built for northern european climate only convinced me I did the right thing by avoiding them.
I dont think I ever saw one that wasnt either just rebuilt or needed rebuilding.
spoken like a true skeptic there Noel :domokun:
if unloved and just trashed any car is terrible. with a little love and some extra oil they are quite happy cruising around in the heat. plus a basic long block rebuild costs less than 1400 bucks, thats a win :cheers:
as for the rotary idea, that was/is still my plan for when i ever break my VW motor (as it will never be a daily...or need to be overly reliable again). and supercharged ones hanging out the back of a low bug does look pretty phat.
Spoken like a true "i've never owned a vw, but i've heard others complain about them, so i'll make the same complaints" man. A close relative of the "i've never owned a 300z, but i hear things about engine removals..." man.
You're cluless John, Have i owned one, Hell no. too smart for that but i bet there have been more of the f**ken things in my family than you've probbly even seen. From stock woosty's to fastbacks to manx buggys. The buggy was a tunna fun till we flipped it with 8 blokes hangin off it.
If you want to nurse them around they are fine to a point but they will never outlive a watercooled engine in a tropical clime.
You start moddin the fokkas and they're more trouble than a rb.
Farkin righto, calm down... jesus.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
