Werd.
Could always come to ikes cream tonight though :thumbsup:
Nah, won't make it in time. Gotta go to the gym at 5, and then over to Germside after that to go to Kmart. Won't get out of that shithole till close to 9 irection. Then home to have dinner and go to bed to get up at 5:30 to do it all again tomorrow :down:
Ordered some gopro stuff off the web a month or so ago. One of the items wasn't in stock, they told me it would be a couple of weeks so I said that was fine.
Got sick of waiting today, here is the email trail:
Hello,
Could I please get an update on the status of my order?
Thanks,
Martin
Hi Martin
Apologies for the delay.
The Skeleton housing is still out of stock and the last coversation we had with you, you wanted the order shipped out together. We have the other products in stock so we can send those out to you in the meantime and leave the skeleton housing on back order, up to you?
Kind Regards
Sylvia
Hi Sylvia,
Do you have an updated ETA on the skeleton housing? I am pretty sure I was told it would be a couple of weeks.
Regards,
Martin
Hi Martin
I have followed this up for you and unfortunately the supplier was unable to give me an approximate ETA on the skeleton housing. It appears they are now on back order, apologies for the delay.
Kind Regards
Sylvia
Hi Sylvia,
In that case, can you please just remove the skeleton housing from the order completely and ship the remainder. Don't worry about leaving the housing on back order for me.
Thanks,
Martin
Hi Martin
Great news, we have just received the skeleton housing in stock. Would you like to keep it on your order? Also, i just called your mobile as i will need to get your credit card details again as we dont store them. If you could please call me back on __________.
Kind Regards
Sylvia
Farkin lol.
You get stuffed about with everything you buy in store these days aswell.
Approximately as such today
Stratco: we've got the sheds you ordered now
my dad gets the trailer out, goes there
Stracto: we don't have the sheds
Edited by sneakey pete
That wasnt being cranky that was wisdom.
Gotta go northside to see a man about a dog tonight so I'll pop in for oiks creem on the way back.
sounds exactly like a certain tyre shop. Ordered tyres and got told they will be there at 2pm. rang at 3.30 to confirm they there and was told yup. Jumped in car and told boss i would be back in 30mins. Got there after battling traffic for an hour to be told that they are not here. WTF.
The story i was told is another person called craig ordered tyres that morning and they were confused.
They ended up deliverying them to me next day so that was good.
makes me laugh tho
    • Please use a modern ECU. PowerFC with the Nintendo Gameboy controller is horrible. It's not 2005 anymore.
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
