Sucks man.. did you manage to make it home with it like that?
Almost :P
Didn't quite make it so walked the last bit home and picked up a compressor to pump it back up
dam man, howd that happen??
Pothole :(
P.S. Morning Mangs, TFIF.
Edited by Smity42
In other news... I got a text from some random number last night that I think might be a ghost text. If I opened my message program, it wouldn't show me the message anywhere. But if I used the drop down notification bar I could read it. Then after I closed it, it still wasn't showing up in my message list, and of course wasn't in the drop down bar anymore either now that I'd accessed it.
Also, it was a message about my wheels for sale... But I've only given my number out to two people, both of whom I have had texts from already...
This leads me to believe I are being of teh hauntedz :huh:
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
