Lol, one of my half shafts is completely f**ked. There's an arc of oil around the CV joint where it's been spraying out :/
Good time to get them rebuilt I think, while the car is off the road for the clutch...
Yeah it was massive, about 90 pages of that is text. The rest is graphs and simulation data etc. The pdf of it was like 9mb lol, I doubt the lecturer will read it all.
sooo, anyone know a good Moderator on here that i can ask a question and will listen?? ive had a post modified elsewhere in the forums...and am non too impressed with the abuse of power...as it could only have been a mod that did it.
Don't go there brah. Last time I did I got sent to Auschwitz for like a month >_<
But if you really wanna push it... try Col_GTSX or whatever close approximation of that his username happens to be. Can't be sure off the top of my head if that's it.
Christ. Went to chermside to do a few things( new parking thing is cool. can see where there are parks by lights) and found a shop that you choose a soft toy and they fill it and you can choose outfits fir them. End result with 3 kids in tow.... bill for $185!.
Never have kids people!
beached as? as for the mod question earlier.....im far to lazy to chase it up. if people wanna be douche bags or internet warriors, so be it........and i still dont get it
i take my bike to chermside, new parking system is good, but i'll always get a park right near the entry undercover :thumbsup:
Girlfriend hates the new parking system though, staff have to pay for parking, they get staff rates but if you start late there isn't enough parks for the staff then they have to pay full price, $20 a day
Edited by Dan_B
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
