Dan [ERD] has posted this previously, and it's not the be all and end all of oil tests but it gives you a good guide:
http://www.animegame...Oil%20Tests.pdf
wowsers. very interesting test.
seems ill try something else next time, royal purple seems the go!
but only a few of the full synthetics seem to actually look different. the rest is all very much the same with a different pretty pattern. funny how some of the cheaper oils are much better than the exy ones of the same brand.
so acording to that if i were to buy penrite it would and could only be the fully Syn....which is funny cause i used all the expensive SIN oils in my box and diff......and they blow. it was a bit nicer for about a month then back to a sticky 1-2 change on cold winter mornings (only the first change or 2). and the noise and feel are back to exactly as they were. will be trying the Redline next time on those.
nice!! decided you needed more to fill your time??
anyone here have a windscreen squirter motor for an R33, mines dead. the rear one works fine so hope fully i can just find the motor for the front one >_<
We needed a motor for the ute so instead of just buying a motor and box we decided it was better to just grab a whole car. Should keep us fairly busy :thumbsup:
Morning Mangs
Morning Mangs,
Monday :(. But last week of work :).
Finished 24 hours of le mans last night, epic. Just nurburgring to go now...
that sounds like an interesting oil you running there smity. hows the oil pressure? im still vary wary of penrite.
I noticed low pressure earlier this week, but to be fair it is quite old and I did accidentally top it up with the oil I use for the XF before happy laps... so that probably didn't help. I changed the oil and filter that arvo (using the penrite SIN again) and it has been all good since then. No issues with pressure other than that.
http://www.animegame.com/cars/Oil%20Tests.pdf
I am guessing mine is the same as the full synthetic penrite in that, just marketed under the "SIN" branding. Seemed to do pretty good in the test.
I use SIN in the diff - no complaints. Also use SIN brake fluid and it is good too.
Redline LW shockproof for the gearbox, that stuff is magic. Although, Noel, Gervase, and ERD Dan all seem to have had some issues with it forcing its way out of the breather, this has not been a problem for me so far.
Mangs,
[snip]
That is all.
What a sh*tbox! :P
Yeah it's a heap of shit lol. But it has some gauges and a pretty steering wheel and a brand new loom apparently so should be good. :thumbsup:
Yeah same mang. Trying to achieve as little as possible this week. It's 8:30 and I havent left the office yet. Great success.
same. been sitting here doing emails.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
