This is possibly old, but way more awesome than hyandai-ferrari:
http://www.themyster...s-basement.html
this guy did it smaller - no need to knock out his wall :P
took him 3 years to draw it... 12 years to build it
Who is interested in a session of paintball for my 21st? Trying to organise a day on the 4th of Feb at samford 12-4:30. Need to get numbers and a $45 deposit pretty soon. I have 20 VIP voucher thingos that I got at Christmas. The deal is $40 and that gets you all of the equiptment and a session of paintball. That's paid on the day and then extra for however many paintballs you need. Let me know.
Quiet night in the valley was quiet. Trialled at Kaliber last night. I might end up passing on the job. As much as I need work, and this would have been the highest paying job I've ever had, I know I wouldn't be right for the job and I don't want to be working 50-60 hour weeks. I thought it was a part time bar manager job, turns out they were after a 2IC for the venue. I'm trying to get away from management so I can go back to uni full time. All I want is about 30 hours a week and a job I can leave at work.
I have a trial at Bar Alto on Wednesday and shoul have one at the Elephant and Wheelbarrow later in the week as well so at least I have options and I'm going to keep lookin beyond that as well.
Morning Mangs,
Finally booked on 18th Feb (Saturday) 1pm 4 people. 5x 6min session.
Yay! :banana:
Also keen for Paintball.
I didn't know we had an Elephant and Wheelbarrow in bris! Should do a club dinner there.
Good luck with the continued job hunting.
Hrmmm. touch call. Give me a holla if you want a drunken idiot to throw out...
Wait, don't we have 5?
Brandon
Colin
Scott
Martin
Kyle
:blink:
I didnt know he got the ticket too. Can someone confirm and I'll call them up and add 1 more to the list. Hopefully its not too late.
edited: Kyle aka EAT26 just told me he didnt buy any. Which Kyle are we talking about?
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
