Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
Lakeside Open Sprints - Sunday 29th August. Get amoungst it. I don't want to be all alone
If everything goes right at ERD this week I am in.
Bigger brakes will be on and got some wheels with correct fitting tyres ready to go
You pay per driver, so no.
However, if they do passenger runs at the end of the day I can take you for a spin. Bring a helmut
NP :)
Awesome :banana:
Awesome :banana:
+1
However, be sure to take it easy if Lakeside is your first sprint outing. It's a killer track, and there is no room to make a mistake (except at hungary). Stick to 8/10ths or so.
BTW John, remember that argument a while ago about giving way to every lane when entering a road?
While I couldn't find any legislation on it, the accepted rule seemed to be you had to give way to the lane you want to enter + 1 lane over.
Well, some sped completely failed to do that today and drove out almost straight into me as I tried to change lanes into the left lane :)
I was indicating for ages and everything, useless cocknugget. Lucky for him:
a) I (unlike him) have situational awareness and saw him about to crash into me
b) Knew (due to the aforementioned situational awareness) that I could swerve back into my old lane without hitting anyone
c) Had time to do b) (just)
d) Was in the Skyline, which I care about getting all banged up, and not the XF, which I would happily write off with with someone else at fault. If I was in that, I would have smashed the accellerator down and ploughed into him
Useless c*nts, should be allowed to shoot them or something
/rant
That's exactly why the legislation used to say "all lanes of traffic must be clear before entering". But as we discovered last time, it's not in there anymore and I rescinded my argument/statement/comments. I still wait for all lanes to clear though because of dickheads like the one you encountered. They'd change lanes into me and be two blocks away by the time they realised anything happened.
And thanks for the suggestion before. It was worth a look. I might just have to save up and buy the whole word :)
f**k Russell Island. Went to a house party there one night because I thought awesome a party on an island it will be the bomb. Think again f**kface, that place is like going back in time. f**kin hellhole.
I was in fear of my car being jacked; I felt I had some sense of security though as up the street there was a few demountable buildings with the words "POLICE" on the door.
Caught a cold, didn't get the job I applied for and had to wait 10 minutes for my nuggets to cook at maccas this afternoon.
Sad day for all.
I'll accept "the lane you want to go into plus 1 lane over" as being sane :ermm:
Thanks mangs, knew I could count on you :ermm:
The increase from 55 cents to 60 cents was not objected by the Australian Competition and Consumer Commission (ACCC) nor by the Minister for Broadband, Communications and the Digital Economy, Senator Stephen Conroy.
Oh look, yet another thing to blame that asshat for :)
Edited by Smity42
    • Assuming the current ECU is stock, it might be worth getting hold of a nissan data scan cable. It could be as simple as voltage at the ECU
    • You need to test for spark when it matters - ie cranking. Kill the fuel supply, pull a plug and earth it, set up a camera and go crank. The spark needs to be consistent, every other turn of the engine. Not some sputtering of occasional spark. The reason I say this is because spinning the CAS in the air is not the same as spinning it installed, and if there is a bearing problem in it, the disk might work differently in the air than in the engine. You won't want to try to set the timing unless you know the spark is happening right.  Also, reconsider running the R35 coils against the stock ECU. They like a different amount of dwell cf the originals. It's not massive, you can actually run them, but it is better if you can adjust the dwell (which you can with Nistune in the stocker, or with an aftermarket ECU). Besides any of that - when you had the multimeter out, have you got power where it needs to be, earth where it needs to be (and when, in the case of igniter triggers), etc?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
